メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
日本の電子機器メーカーであるHitachi(日立製作所)のテレビに関する修理ガイドおよび修理情報です。
Hitachi tv random crashes
Hi,
I've got an hitachi tv model number l22dp04u a, and ive got an issue with that i cant seem to constantly replicate.
The TV will turn on a work as normal until a after a random period of time it will make the speakers pop then either a set of green and purple or 2 shades of grey lines will appear on the screen.
Unplugging the tv and and leaving it for a few seconds returns it to normal until it does it again after a random amount of time.
It seems to be worse once the TV gets warm but im struggling to get any ideas of what is going on, i have googled the issue but can't seem to find anything similar to the symptoms.
Anyone have any idea if its likely to be a main board or a psu board issue.
Regards
Ian
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@porkchopsachunk this "the speakers pop then either a set of green and purple or 2 shades of grey lines" would lead me to check the main board first. Of course there are still plenty of other possibilities and we would need to see what your boards look like etc. It probably overheats a component which then causes those issue. Possibly a voltage regulator or other IC on your board. Remove the back cover form your TV and look at the boards (don't touch just yet:-) see if you can find components that look discolored etc. Post some good pictures of your boards with your QUESTION. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ian blackburn さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 35
今までの合計 387
