メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Surface Book 2 15", マイクロソフト社製ハイブリッドノートPC/タブレットの15インチ版の修理ガイドです。2017年11月に発売されました。
Is this a fry mark?
画像
Found a Surface Book 2 from the ewaste. I tried plugging in with a type-C charger but it doesn't seem to be drawing any power (charger nor the cable are warming up). Holding down the power button to force restart didn't do anything. I haven't tried a surface connector charger yet, but is that mark on the surface connector an indication that some sort of short might've happened? This seems to be the 1060 dGPU model and it would be a shame for it to be left to the trash
Oh also warranty's already expired so unfortunately I can't Tom Sawyer this thing like I did with my 2015 Macbook Pro's battery
Update (04/12/2022)
So turns out the top seems to work fine after detaching it. I'll look more into why it wouldn't charge through the type C, it's possible that the power delivery circuit might be shared (given that the surface connector can also transfer data, it makes sense for both to possibly share connections). Unfortunately looking at the teardown guide the suface connector-side of the laptop isn't on its own daughterboard, unlike the usb-a connector side, and getting into it also would be really difficult regardless
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Yea. That's probably why it's in the garbage. You could order the part and try to fix it though.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I wonder what happened to the charger that did it. Unfortunately anything pre-2019 made by Microsoft is incredibly hard to take apart and fix. Hopefully the top part still works
さんによる 共有
コメントを追加
Hi!
I think you should be careful connecting something to the equipment since the image shows what could potentially be a short. I also know that the USB-C port can only be used to charge other devices, like a smartphone, but can't be used to charge the laptop itself.
I have bought a cheap Microsoft Surface Book 2 charger clone from Amazon that works just fine.
You also could try to purchase the keyboard part from AliExpress or Amazon, I know there are some replacements around the market.
Or you could also look for a neu keyboard part at e-Bay.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I'm pretty sure the Surface Book 2's type-C has charging enabled (actually someone wrote a post about it https://dancharblog.wordpress.com/2018/0...) and I was testing with a 100W USB-C charger. I ended up buying a parts surface book 2 with a working bottom, although I kind of regret wasting money on it since I ended up not daily driving the Book 2 :/
But yeah I assume the circuitry between the type-C and the surface connector might be shared, since you can only charge from type-C when the surface connector is not in use (I guess it prioritizes power from there), which would explain why the surface connector frying killed the type-C connector as well
さんによる 共有
コメントを追加
回答を追加する
watercannons さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 27
今までの合計 1,294
