メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
フレンチドア、ビルトインデザイン、自動製氷機を備えたボトムフリーザーモデル、Samsung RF28HFEDB冷蔵庫の修理方法および詳細情報を確認できます。このページでは、モデル番号RF28HFEDB**に該当するモデルの情報を扱います。
Ice Maker Not Working
We purchased a second hand Samsung refrigerator RF28HFEDBSR/AA Everything was working at the time of purchase. We moved it let it sit for a week then installed it. The water dispenser works fine but it is not producing ice.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
12 件のコメント
What model of refrigerator
さんによる 共有
Samsung RF28HFEDBSR/AA
さんによる 共有
@wiccapheonix - Can you take a video of the inside and outside while its trying?
さんによる 共有
I could but theres nothing to show, it doesn't do anything. No sound at all
さんによる 共有
@wiccapheonix - A video would be kind of helpful,
Make sure its not blocked try running a small amount on water though
さんによる 共有
7件以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
Hi @wiccapheonix
I can't find a service manual for your model but here's the start of the ice maker troubleshooting flowcharts that may help.
It is for a RF28H series so hopefully it may be close enough to be of some help.
If you can't hear the ice water inlet valve when the ice maker test switch is operated, check the wiring connection to the valve (location is shown in the link - this IS for your model). It looks like there are 3 valves, so it will be a main supply, dispenser supply and ice maker supply. To get water to flow the main has to be operated as well as the desired individual valve i.e. for dispenser it is main and dispenser valves, for ice maker it is main and ice valves. As the dispenser is working obviously the main is as well. So you need to work out which one is the ice water valve
If it seems OK then on p.50 it shows how to remove the ice maker so that you can check if there is water in the tray or not.
Also on p.60 it shows how to get into the diagnostic tests mode which may help.
Sorry I can't help further and especially if the manual isn't relevant to your model
Supplies water to your refrigerator's ice maker and water dispenser.の画像
製品
DA62-04027A - Samsung Water Inlet Valve
$158.99
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks!!! I will give this a go!!!
さんによる 共有
@jayeff - Well said!
さんによる 共有
コメントを追加
回答を追加する
wiccapheonix さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 18
今までの合計 1,410
