メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2017年に発売されたHP Envy 17tの修理ガイドおよび技術仕様です。HP Envy 17tは、17インチのディスプレイ、16GBのRAM、Intel Core i7プロセッサを搭載しています。
Why is my computer overheating while off completely?
I have an HP Envy 17t that is a few months over a year old and the problems that it has started a few months after and Hp customer support is no help, the main issue is that it will be completely shut down and it will overheat to the point of burning my hand. I have tried everything that I know to try and find the issue to the extent of making it a brick with no software on it, then reuploading it. I have also found that when I open the lid the lights will sometimes be on as well, and it kills my battery. I am now desperate for information on this problem, because I have thought of everything I know, and it hasn't helped.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
There's a couple of things you're going to want to do.
  • Make sure that your machine's air vents are clear of any debris or dust
  • Open the device up and make sure that the cooling fan is clean actually running
  • Ensure that your CPU's surface is clean and has a proper amount of thermal paste.
I did find a guide on how to get into the device to inspect the internals. I'll link it here, but you'll only need steps 1 - 11. I'd also attach pictures if you do get the opportunity.
iFixitの画像
ガイド
iFixitでの質問に画像を追加する方法
難易度:
とても簡単
2 - 5 minutes
HP Envy 17t ディスプレイパネルの画像
ガイド
HP 17t-k000シリーズ ディスプレイパネルの交換
難易度:
中レベル
1 - 2 hours
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Justin Boge さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 307
