メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Chromebook 11シリーズの修理ガイドおよび技術情報です。標準的なクラムシェルモデルと2-in-1コンバーチブルモデルの両方に対応しています。ディスプレイ、キーボード、バッテリー、その他のコンポーネントの分解、交換部品、一般的な修理方法を網羅しています。
Why does my keyboard not respond?
I bought my chromebook refurbished about three months ago, and the keyboard isn't quite working right. When I type fast or the internet connection is slow, not all of the keys respond and the backspace bar freezes, resulting in mixed words with multiple missing letters, such as veins to showashe bms mo agrsseandolt wihe child. This is supposed to say begins to show as he becomes more aggressive with the child (this is from an essay I'm writing, don't question it). Is there any way I can fix this or should I send it somewhere?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
typing generally around the system or online such as Google docs?
さんによる
It happens wherever I try to type if that's what you're asking
さんによる
コメントを追加
1 件の回答
ベストアンサー
So a couple of things might be causing this issue. For starters, you're going to want to Power Wash your device. If something like an application is causing your CPU to be bogged down that might be the culprit.
I would also open the device up and check to make sure the keyboard cable is seated correctly. In addition, I have seen a few Chromebooks where the ribbon cable for the keyboard is creased by the battery. This causes damage to the cable and will result in the connection to the logic board not being complete. If you do open the device up definitely take pictures and upload them here.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Gianna Hemming さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 21
今までの合計 546
