メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Netgear ルーターの修理、トラブルシューティング、および分解ガイド。
Wifi randomly turns off
So my parents recently got a nighthawk wifi six router (I believe the RAX200). For the most part it runs fine, but randomly the signal will drop.
I’ve already tried updating the firmware, and I’ve already reset it once. They all resolve the issue for a a while, but it does comeback every now and then.
It doesn’t happen that often, but since my parents are using it for their business, they don’t want to risk it dropping during work hours.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi Omar,
If you have just recently purchased it get an get RMA from Netgear and get a replacement. If you start opening it up, etc. the warranty will be void.
Contact Netgear support.
https://www.netgear.com/support/
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi @coolmon
If you have a Windows PC try downloading, installing and running this free WiFi sniffer program.
This will let you know the signal strength of your WiFi network (-ve dBm value, so the higher the number, the lower the signal strength) and also if there are other WiFi networks nearby that may be operating on the same channel and if their signal is strong enough can cause interference.
If other networks are on the same channel, switch your router to a quieter channel i.e. no appearances in the WiFi sniffer program. Most routers default to Ch 1, 6 or 11 (if using 2.4GHz) straight out of the box and nobody bothers to change it. Check the settings in the router setup if you want to change it.
If you have a laptop, try the program on the laptop and run it close to where your parents use their connection and measure the signal strength there. -40dBm to -60dBm is considered to be excellent - good signal strength values. -70dBm and up e.g. -80dBm, -90dBm etc and you start to run into problems. The same if the signal is too strong i.e. -20dBm to -30dBm, it could then be overloading the adapter which also causes problems.
If the signal is low where your parents need to use it, try boosting the signal or moving the router to a different position and measure the signal again. I haven’t checked the user manual for your model but most have a “boost” type setting which can be enabled/disabled if the signal is too weak or too strong (if enabled)
Internal walls and electrical appliances (especially when first starting e.g. Air Con, refrigerator compressor etc) can also degrade the signal, so something to watch out for since it is intermittent.
This is all assuming it loses connections and not that the router switches off etc.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
That makes sense. Something interesting to experiment with. Good information. Thanks jayeff.
さんによる
コメントを追加
回答を追加する
John Doe さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 24
今までの合計 1,187
