メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sharp テレビの修理情報。
TV Has Sound But No Picture - Help
Hi guys. My sharp E42E41NKFMBSNNX has no picture but has sound. I tried replacing the hdmi cable, plugging it into another hdmi port and factory resetting and nothing works. How Do I fix it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
the problem is the backligth Led's i have many t.v. repair with the same problem ,and always have some Led's dead
さんによる 共有
コメントを追加
2件の回答
ベストアンサー
Hi @koolx
Factory resetting it means that you can view the TV menu screens OK, is this correct?
If possible try using another signal source using HDMI e.g. dvd player, pvr, laptop PC etc and check if there is video on the screen or not.
If there is then there may be a problem with the signal source and not the TV.
If not, then if possible try using another input connection type between the signal source and the TV e.g. component video (red/green/blue + red white cables) or composite video (yellow, red, white cable) and check if there is video or not. It may be a problem with the HDMI controller in the TV. I couldn’t find a TV user manual online so I don’t know what connection options are available.
Update (03/06/22)
@koolx
Just thought you needed the menus to do a "factory" reset. Did you use the remote to code in the factory reset then to do this?
With the TV on and audio heard, shine a torch (flashlight) at an angle close to the screen and check for any images on the screen.
They will be very faint if they are there so trying in a darkened room may help to see them.
If you can see images with the torch then there is a backlight problem. Either the LED backlights, the power supply or perhaps the mainboard not turning the backlights on.
Sharp is difficult as they don't release the schematics/service manuals to the public so it is difficult to know what the correct voltages should be on the power board.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
No, I cannot view the TV menu at all. The screen is completely black.
I tried plugging the hdmi cable into another TV and it works. So the culprit is not the cable, its the TV.
さんによる 共有
コメントを追加
If you are using an antenna on your Sharp TV , make sure it is set right and Signal is available.Wrong or displaced position of the Antenna more usually cause Black screen on my Sharp TV.
Check your TV Settings -Try to Change the Display or Picture settings if it works.
If nothing works,there are chances of possibilities that your TV Panel are faulty.Best is that you use your Sharp warranty and get it fixed if it is more critical issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
koolx さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 31
過去 30 日: 118
今までの合計 5,009
