メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Casio fx-9750GIIは、カシオ計算機株式会社から販売されているグラフ関数電卓です。電卓の前面右上隅に「fx-9750GII」という名称が記載されています。
Why are my function keys not working properly?
My function keys are not working properly.
In Run-Math program, if I press F1, nothing happens. If I press F2, it opens a list of options in the botton (LIST, MAT, CPLX, CALC, STAT). If I press F3 it opens another list of options (V-WIN, FACT, STAT, GRPH, DYNA). If I press F4, it acts as going into the previous screen (For example, If I am in Run-math and I was in the menu before, it goes to the menu and if I press it again it goes back to the Run-math). F5 acts as the Left arrow key in text editors. F6 acts as moving back a line (selecting the previous line).
Every other button work as intended.
I tried to reset the system through the menu, but since the function keys aren’t working properly, I can’t select the reset option. I’ve also tried the small button on the back of the calculator, but it doesn’t do much.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Hello Ricardo, did you maybe had a spill onto the keyboard?, also if the unit is old, ( i don’t know how old) some buttons might stop working , like buttons of tv remotes, it might be worth it to open the whole thing to have a look if its dirty or worn out . if its worn out, there is a conductive glue available from specialised electronic shops, just cover the tip of the missing carbon rubber with a very thin layer of the conductive glue , wait for it to dry, reassemble. also while you have it open, maybe then you can check if bridging corresponding pad of the reset option would do anything. good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try to redownload the program. I had the same issues and it helped me. It gave me a lot of problems because I used it for education. Fortunately, this site https://plainmath.net/textbooks/ saves me from failing lessons. But maybe someone has other more smart suggestions?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ricardo OKay さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 33
今までの合計 1,509
