Why does my dryer immediately shut off after pressing start?
I have a kenmore elite model 796.61523210 that will power up normally but immediately turns off when I press the start button for a cycle.
The metal frame is also energized when the start button is pressed (I was touching the back one time and as soon as I pressed start I got a lil shock)
At first I thought the outlet might be wired incorrectly (I just moved from Florida to VA and transported the dryer in a haul) so I checked that & the outlet and dryer are both wired up correctly i.e. common and both phases are in the correct spot and +-120v to each phase.
I pulled it apart to see if any wires had pulled out or lost insulation that could have caused this with no luck. All of the grounds connected to the frame are good also so not sure why it would be energized. The only thing I could think would cause that issue would be one phase hooked up to the ground terminal.. any other ideas?
I also tried it in air dry mode to see if it was an issue with the heating element but no difference there, all coils measure ~24 ohms and none are shorted to ground.
Any suggestions for troubleshooting this? Or another website I could post to that may be able to help?
Thanks!
Video: https://imgur.com/a/QdQNcL4
この質問は役に立ちましたか?
1件のコメント
I tested the ground in another outlet on another circuit breaker - touching the frame of the dryer and a probe in a separate grounding socket shows continuity, and I’ve tested voltages on the outlet and the pigtails on the drier to make sure the ground and each phase are wired up correctly.
I am stumped as to what else could cause this though
jrfinn さんによる
