メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
初代Altimaは1992年6月に1993年モデルとして生産が開始されました。1993年型から2004年6月まで、すべてのAltimaはテネシー州スマーナで製造されていましたが、需要の増加に伴い、ミシシッピ州カントンにある日産の工場でも生産が開始されました。
has problems starting most of the time
I have a 94 Nissan Altima 4 cylinder that has problems starting most of the time. If I pull a plug out I am getting spark and it allows the car to start, but put it back in then it doesn't start... Help please...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Dave Scott could be many of things. If it has spark it most likely has spark when it is back in the cylinder head. So that would leave either fuel or air as a possibility. Check your fuel filter and pump to make sure that you have the right fuel pressure on that. The other thing you need to check for is that the spark happens a the right time. So you need to check the crank position as well as the cam position sensors. I would strongly suggest that when it runs, take it where they can scan the vehicle 's OBD to see if and what codes you get. Otherwise you might be spending a lot of money for parts that are not needed. Depending on where you are, places like Autozone do the scanning for free. Let us know what the exact engine is and what you have checked so that we may provide a more in depth answer
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I have replaced the fuel pump, battery, and fuel injectors it is getting gas, also should note that after replacing each the car started like the problem was fixed I shut it off came out next morning back to not starting, has me very confused. Was going to take it to shop down the road but won't start now..
さんによる
Sorry, forgot to also mention the spark plugs and wires were also changed recently.
さんによる
What about the cap and rotor?
さんによる
コメントを追加
回答を追加する
Dave Scott さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 472
