Laptop is not working
It comes up with this message: error sending end of post message to ME: HECI disabled proceeding with boot acer and this
https://appuals.com/fix-error-sending-en...
This should help you
このアンサーは役に立ちましたか?
Unfortunately it won’t turn on at all now every now and then it shows the squiggly lines but that’s it :(
Try contacting support
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 767
Can you change it to legacy boot?
NR26 さんによる
Hi I pressed f2 and my laptop came on is there anything I should do next as some times it works but the same thing happens?
Millie さんによる
@milliefirth1 Could you possibly send a picture of that screen that it brings you to, also try F10, F12, F4
NR26 さんによる
It lets me just go on my laptop like normal however I had this issue before and it fixed itself but it just ends up randomly turning of and then repeating the process
Millie さんによる
