iPhone 12 Pro Max cracked
My iPhone pro max has a battery problem which keeps turns of every minute and front screen and back has a crack ?
Did you already replaced the battery ? If not, your battery is probably end-of-life. You can replace it following this guide : iPhone 12 Pro Max バッテリーの交換
Regarding the crack in the front screen, the repair guide is here : iPhone 12 Pro MAX スクリーンの交換
Regarding the crack in the back, I would suggest to simply add a case for your phone (this will also protect it from further cracks. I would suggest to also add a screen protector (simply search for it on your prefer search engine / online retailer).
Hope this helps.
ガイド
難易度:
中レベル
1 - 2 hours
ガイド
難易度:
中レベル
1 - 2 hours
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 4
過去 30 日: 33
今までの合計 1,029
