メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xbox Originalは、Microsoft初の広く普及したビデオゲームシステムです。上部と前面に「XBOX」のロゴが入った、識別しやすい黒いケースが特徴です。一般的な工具で簡単に修理できます。
What is this white stuff on the power supply?
I opened it up to check on the clock capacitor and got scared that the capacitors on the power supply had leaked out and was somehow still working.
画像
Xboxの電源ボードの交換
Every replacement power supply I found and the one in this guide also had it though. Is it just bonding?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
@alexanderson that is some silicone based “goop” that keeps the components in places, isolated from the other components and stops them from vibrating. PITA to remove it. Most of the time I use a heatgun and a dental pick. No fun and messy but normal stuff.
このアンサーは役に立ちましたか?
スコア 6
7 件のコメント:
Okay that's good to hear. What would you recommend to get the main board nice and clean? Currently there's a thick amount of dust in there.
さんによる
Start with a brush and brush the lose stuff off. Then use a bit of compressed air or a shopvac (or similar) and blow the more resistant stuff off. Keep on brushing the dust off as it gets lose from the air.
さんによる
You can usually remove them without removing the stuff, but you need to remove all of the solder. I've done it out of laziness before. It's more prone to risking PCB damage yes, but if you do it right it's a huge time saver - just don't re-apply new goop.
さんによる
@nick - I always put back the thick silicon damping potting after replacing the ones that are potted. Otherwise your power supply will ring! The caps and coils oscillate to the 60Hz cycles or its harmonics.
さんによる
@danj Heh I never notice, tbh.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Thomas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 30
今までの合計 2,698
