How to replace the glass screen
How to Replace glass screen
@pattyv56 the glass is adhered the the display. Not an easy repair and it will require some specialized tools and very good skills to separate the glass and subsequently the re-adhere it. If you have not done this before or do not have the right tools, I am suggesting that you do not attempt this. Unless of course you want to give it a try and get good at it. Check videos like this to see what is involved. If you need the repair on your phone, I recommend that you replace the complete display assembly. Yes, it’s more costly but it has a way higher success rate. Check on here about the How-To for that
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 22
今までの合計 688
