fans are grinding or making a strange noise
I have a razor 15 2019 and it sounds like the fans are grinding or making a strange noise but are working fine. I want to properly clean it and if possible increase my ram from 16GB to 32GB
Max Regni looks like teh part number for your computers fan is DFS5K121144645. check places like this for a replacement. As for the memory we would need your computer model number to determine what you need. for now it looks like you would need
* Unbuffered
Double check with places like this
このアンサーは役に立ちましたか?
my system is the blade 15 mid 2019-base and I am somewhat computer literate but I don't know what any of that means besides that ddr4 has good speeds and that if possible I want my ram to be duel channel
Max Regni you will need this when you order your memory. Of course if you use Crucial etc. you'll find that there website is really user-friendly and based on your computer. It'll be straight forward, no worries about that.
I would do some research b4 upgrading. I found a number of posts that indicated a 16 to 32GB RAM upgrade has little effect unless you are doing some serious number crunching or video editing.
As far as the noise, it may be as simple as dust needing to be blown out, or the fan bearings need lub or maybe the fan needs replacement if they are real bad.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 42
今までの合計 2,208
1件のコメント
Max Regni Let us know the exact model for your Razor.
oldturkey03 さんによる
