メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech G602(ワイヤレスゲーミングマウス)に関する背景情報。
Logitech G602 random button commands upon mouse wake up
So for quite a few months I get intermittent issues with my mouse performing a random key press/command upon the mouse waking up.
Sometimes it’s simple like it’ll input the back arrow if I move the mouse after watching a long enough you tube video for it to sleep so it just goes back in the video 5 seconds. But lately I get weirder commands like one that makes my webpage disconnect from the internet, and/or go a page back from where it was while browsing.
Restart sometimes helps and sometimes it just does another strange command instead. like close the current window I’m in…
Any trouble shooting help would be appreciated.
Running an i9 10900k on Asus Maximus XII, G-Skill royal trident 32GB on M.2 drives
Everything is up to date on Windows and through the Logitech application.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
最も参考になった回答
Hey, I can at least let you know you are not alone.
When my G602 wakes up, it presses random buttons. Sometimes that's just a simple click, left or right. Sometimes it changes DPI settings one notch. Worse however is when it wakes up and triggers the Paste shortcut. Had a bunch of cases where it pastes whatever is in the clipboard into an open IDE window... always great to have youtube links in your code.
I suspect the crapware that is GHUB. It's done a number on my mouse, like no longer being able to change the hardware stored profiles and other nonsense.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Well this seems weird. I have used G602 and that never had any problems whatsoever. Anyways, here some common fixes that will help you resolve the issue.
  1. Clean your mouse and connect it to a different port.
  2. Update your mouse driver from the official website of mouse brand.
  3. Check for remote control software.
  4. Use CPS counter to test mouse buttons one by one.
  5. Disable the touchpad for Laptop users.
  6. Disable the ClickLock feature (for Windows PC).
I am sure at least one or two steps from the above will help fix your Logitech G602. If not, just ping me up!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have a similar issue, when I power on the mouse, one of the side buttons seemingly keeps clicking and inputting the number "2". I tried disabling the side buttons in the G Hub app but that only worked until the next restart.
The problem disappears once I unplug the receiver and plug it back in. That is, until I turn off the mouse for the night and turn it on again.
さんによる
コメントを追加
I have the same problem, upon waking the mouse, the list of "fixes", stated above does not fix it. As also stated above I believe ghub is the culprit. I can either have the buttons assigned to common useful tasks such as forward, back, volume up, volume down, and get the random button presses on waking the mouse, or have the buttons unassigned.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yep, same here. Random button inputs on mouse wake up. It's been happening off and on for months. I also suspect it's ghub. Nothing I've tried fixes it.
さんによる
コメントを追加
回答を追加する
Cody Gibbs さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 20
今までの合計 1,132
