メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Lenovo 500e Chromebookの修理情報。2018年発売。モデル番号:81MC0000US。
Chromebook left corner falling apart
I dropped my chromebook a few times and the left corner of my chromebook screen has started falling apart. It is a school chromebook and I do not have the money to replace it. Any way I could fix it? Here is a picture showing the part that is breaking: https://drive.google.com/file/d/1yxogIhO...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @gohawks4600,
It’s a bit hard to see in the image you posted but the problem is either with the Strip Cover part # 5CB0T45070 or the LCD cover part # 5CB0T70888 or both.
The suppliers shown above are examples only to give an idea of what the part looks like and what the cost may be. Search online using the part number only (for whichever part is broken) to get results for suppliers that suit you best..
Here’s the hardware maintenance manual for the laptop.
Go to p.44 to view the necessary pre-requisite steps and then the procedure to disassemble the LCD module. This details how to remove the strip cover and also once the LCD panel is removed etc the LCD cover (aka lid) can be replaced.
Both parts are made of some sort of ABS plastic or polycarbonite type material so it may be problematic if it can be repaired by gluing the broken sections as some adhesives react badly with these and don’t hold. Unfortunately you won’t know until you try them. You could use an epoxy based adhesive perhaps to mend the broken piece(s). Search online for an epoxy adhesive that is made to be used with most plastics. Here’s a link that may help with this.
Serves as a bezel trim around the laptop's LCD screen, preventing debris from entering the display area.の画像
製品
5CB0T45070 - Lenovo Laptop Strip Cover - Genuine
$67.99
Genuine Lenovo LCD cover for the 500e Chromebook 2nd Gen, including built-in antenna.の画像
製品
5CB0T70888 - Lenovo 500e Chromebook 2nd Gen LCD Cover With Antenna
$68.99
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you so much!
さんによる
コメントを追加
回答を追加する
Matthew Hinkleman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 28
今までの合計 1,782
