メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
856回答 すべてを表示
People can’t hear me on calls, or FaceTime etc
Hi,
Have got a iPhone 8 , people can’t hear me on any phone calls, FaceTime, etc . Have tried using voice memos to record and doesn’t pick up any sound.
When I record a video with the back main camera it does record sound. And sound plays ok .
Is this a speaker issue? And which one would need changing?
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Have you tried using the speaker phone mode on calls?
さんによる
Yes still don’t get any joy though.
さんによる
When i call on discord or facetime or instagram my friend cant hear me but i can still hear them. I reset my phone i deleted the apps and downloaded them back and im still having this problem
さんによる
コメントを追加
2件の回答
ベストアンサー
This sounds most likely like a bottom microphone problem. As was already noted, I would try and make certain there’s no debris stuck in the bottom grills. Although it was mentioned to use compressed air, I would recommend using something like Blu tack, or even tape to pull stuff out since that’s generally more effective than trying to blow it inward.
If it looks clear, it may be the microphone itself is not working properly in which case you’d be looking at replacing the lightning dock assembly.
iPhone 8 Lightning Connector Assembly
iPhone 8 Lightning Connector Assemblyの画像
製品
$24.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hello,
2 questions:
  • Are you using headphones? And if you are have you tried switching them out?
  • Have you tried blowing out (GENTLY) the speakers with some air?
To remove the dirt in the microphone:
  1. Open some compressed air
  2. Blow it at the grill on the top
  3. Blow into the bottom left microphone
  4. Blow into the mic at back on the right of the camera
  5. Most of the dirt should be gone so people should hear you
Another possibility is in your microphone privacy settings:
  • To turn on your iPhone’s microphone, go to Settings > Privacy > Microphone > make sure the app you’re using for calls if toggled on.
Another possibility (very rarely) is your network settings try this to reset your network settings:
  1. From the home screen, tap Settings
  2. Scroll down to, then tap General
  3. Scroll down to, then tap Reset
  4. Tap Reset Network Settings
  5. Tap Reset Network Settings to confirm
You can also try to force reboot your iPhone and that may help your situation:
iPhone 8を強制的に再起動する方法
Lastly you may need to replace your speaker if all else fails:
iPhone 8 Troubleshooting
iPhone 8 イヤピーススピーカーの交換
Good luck!
iPhone 8の画像
ガイド
難易度:
とても簡単
20 seconds
iPhone 8 イヤピーススピーカーの画像
ガイド
難易度:
中レベル
30 minutes - 1 hour
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
dan morrill さん、ありがとうございました!
統計データ:
過去 24時間: 26
過去 7 日: 171
過去 30 日: 819
今までの合計 19,738
