メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG Exalt VN220の修理ガイドおよび修理情報。LG Exalt VN220(LG ExaltまたはExalt LTEとも呼ばれる)は、2018年に発売された折りたたみ携帯電話です。
My screen is black
My phone is working but the screen is black
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Might I ask what you mean by working, and what troubleshooting steps you have followed so far?
さんによる 共有
@isaac8183999 yep, sounds like a bad screen
さんによる 共有
コメントを追加
3件の回答
最も参考になった回答
Maybe consider trying to find a replacement screen or taking it to a expert to determine if the screen has become damaged somehow.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
hi, I'm a technician specializing in Vn220 repair, if you find your screen blank the most common cause is the yellow belt or wire who sends info & electricity to the screen has cut off, so the first step is to replace that wire, secondary, make sure the battery is not the problem by inserting another working battery and see if it turns on,
このアンサーは役に立ちましたか?
スコア 1
8 件のコメント:
is there any way to obtain pictures from this phone without repairing the screen? We have taken it to a phone repair shop and they cannot find this part anywhere. (According to them)
さんによる 共有
@luzer wanna help me with this phone?
さんによる 共有
@escajeda32 If you enabled USB Debugging, that would work to connect your device to your computer or use scrpy. Though the best bet would be to find another phone and swap bottom boards to see the screen to take off whatever you like.
さんによる 共有
@yifi What do you need help with?
さんによる 共有
@fixmylgexalt replying to my post from a year ago... Think I still remember???
But thanks anyway. Also, it says in your profile that you sell these parts.
I might be interested in buying...
さんによる 共有
3件以上のコメントを表示
コメントを追加
I wanted to offer my expertise. I am a technician and have successfully repaired over 100 of these devices.
If you're experiencing a black screen, the issue could be due to one of the following:
1. Flex cable
2. PCB (printed circuit board)
3. LCD
4. Connector on the motherboard
You can find all the necessary replacement parts at primephoneusa.com, which also offers repair services.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Sarah さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 23
今までの合計 1,736
