メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Strange audio/mic problem on MacBook Air
I haven’t been able to find a solution to this for over a year. When I’m on Zoom or FaceTime using internal speakers and mic, I can hear other people but nobody can hear me. Instead of hearing my voice they can hear sounds if I tap on the keys or move the mouse. When I use ear buds, they can hear me but NOT when I use wired earphones. This was fine for a while but now my earbuds are dying and I need to have other alternatives for video calls for work. Please help!?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Sounds like the headphone jack has messed up! What a lot of people forget there is a set of switches within the jack to redirect the audio signal to the speaker output from the headphone. In your case one of the switch element has shorted across the microphone line or the connection between the I/O board to the main logic board has a problem.
Here’s the guide to get it out MacBook Air 11" Late 2010 I/Oボード交換 and you should replace both of these parts
That should fix things.
Replace an I/O board compatible with the Late 2010 model MacBook Air 11 inch laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe power, USB, and audio ports.の画像
製品
MacBook Air 11" (Late 2010) I/O Board
$29.99
Replace an I/O board cable compatible with the Late 2010 to Mid 2011 MacBook Air 11" laptop. Fix the connection between the I/O board and the logic board.の画像
製品
MacBook Air 11" (Late 2010-Mid 2011) I/O Board Cable
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
B K さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 23
今までの合計 239
