メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsungの完全ワイヤレスイヤホン、Galaxy Buds+の修理・分解情報。2020年2月発表・発売。
Is there any HOPE?
I left my Galaxy Buds case with the earbuds inside in my pants pocket and washed them and then dried them as well. They still connect to my phone but the charging case is unresponsive after on the charger for 24 hours. Is there any HOPE???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
i would recommend disassembling the case and checking for water damage on the board and battery. if there is water damage attempt to replace the part. if not just dry it out, DO NOT USE RICE.
If that does not work you can either send it to samsung for them to investigate or you could possibly buy either a fake case from amazon linked below.. or you could buy a used case in good condition from ebay for your exact color if you want ti to resemble the original.
fake galaxy buds case
Hope this helped.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
there is still moisture in the case. put it in a bag or container of instant rice for a week or 2. the rice with dry it out completely. than it should work again unless the battery in the case got damaged. you can buy these and replace it.
https://www.youtube.com/watch?v=StGaoAxv...
the numbers on the battery will help you order a new one normally $5-$10 with shipping from aliexpress.com
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sean Taylor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 34
今までの合計 3,328
