メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年9月20日に発売されたAppleのメインストリームiPhone 11は、6.1インチのLCDタッチスクリーン、デュアルカメラを搭載し、6色展開です。iPhone XRの後継機にあたります。
3 mins Rebooting. Panic Full
panic(cpu 0 caller 0xfffffff02abe87e8): userspace watchdog timeout: no successful checkins from thermalmonitord since wake
service returned not alive with context : is_alive_func returned unhealthy : current fffffffffffc, mask 7fffffffffff, expected 7fffffffffff. SD: 0 BC: 1 Missing sensor(s): TG0B TG0V
service: backboardd,
What do i need to replace in this, it reboot after 2-3 mins but if it is not use i doesnt reboot.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
1 件の回答
ベストアンサー
More than likely this is a charge port issue. Essentially the phone is expecting check ins from the thermal monitoring service and it’s not getting data from 2 of the sensors (TG0V and TG0B) So the phone shuts off.
It could be other things as well, but charge port is where I would start. TG0V I am sure is in that flex. TG0B is battery, and the signal for that may also be carried by the charge port.
このアンサーは役に立ちましたか?
スコア 5
6 件のコメント:
Sir why does also my iphone dont charge, and there is no battery percentage, also when i charge it, it only sound, but their is no charging, even it is connected.
さんによる
@Altair Van Historillo Could be the same thing. If that cable is not working correctly, then it may not be charging the battery properly or reporting charge percentage. That's how the power from the charger is connected to the logic board.
さんによる
i change the charging port cable but still booting up every 180 sec, also i still cant see the battery % not the battery health, and it is also stuck on 0%.
さんによる
@Altair Van Historillo Could also be the battery itself, or the power button cable, which from what I've read elsewhere TG0V may also be in the power button flex cable. Although given the battery related symptoms, I am more likely to think battery.
さんによる
Please is none of these it’s hardware issues go repair your power ic
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Altair Van Historillo さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 50
今までの合計 18,360
