メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
Bad MagSafe board? No indicator light/not charging w/ dead battery
Hey!
Found similar issues on this forum/web but nothing specifically matching my issue,
I have a verified good apple charger but no charge indicator and a dead battery on my machine.
I tried resetting SMC, as well as disconnecting the battery and holding the power button/then plugging in the charger - still no magsafe response. The fans do not turn on even with the battery disconnected (stared at it while the case was off).
I pulled the magsafe board - doesnt look horrible, minimal corrosion if any externally.
Does this sound like a mag board - or more of a logic issue?
Additional: battery was due for replacement but would hold charge a few hours.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Do you have a DVM? If you do check the voltage on the logic board. Reference this guide to locate the logic board connector J7000 MacBook Pro 13インチ Retina Display Early 2015 MagSafe DC-Inボードの交換
Are you able to measure the chargers voltage? If not the DC-In Board is not likely the problem.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Thanks for answer. Can get access to DVM later this week through uni. Will respond again with results. Doesnt look like much I can do in interim without tools.
さんによる
Tests revealed a bad board. Put in a used i7 board with new thermal paste, works wonderfully again! Thanks for the help.
さんによる
@kgapplefan - That sucks ;-{
Don't forget to accept the answer - Thanks!
さんによる
コメントを追加
回答を追加する
Ken Greco さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 210
