ASUS X555QG Screw Sizes
Is there any X555QG documentation on where the screws should be placed? I lost track and now I'm scared of breaking something inside.
I have
4x 9mm
and 6x 11mm.
この質問は役に立ちましたか?
I have
4x 9mm
and 6x 11mm.
この質問は役に立ちましたか?
Hi @banesrb ,
I couldn’t find any information regarding the locations of the screws in the laptop but here’s a list of all the screws that are used.
There are no 11mm screws in the parts list so presumably they are the M2*12L (12mm) screws.
Perhaps you could use a thin wire and insert it into the screw holes and then mark the wire so that you can measure the depth of the hole. A difference of 3mm between the screw lengths should be easy to discern
このアンサーは役に立ちましたか?
I guess this will be close enough, thank you.
過去 24時間: 1
過去 7 日: 1
過去 30 日: 15
今までの合計 1,235
