メインコンテンツにスキップ
Released by Nikon in January 2014, the Coolpix L830 is a compact digital camera designed to provide powerful zoom with simple operation.
22回答 すべてを表示
Why It only turns on with the power supply?
Nikon coolpix L830 started to place messages , card can not be read., i turn it off them On and it worked.
Now the camera does not turn on with the batteries , I plug it to the power supply and that's how it works.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
batteries can be bad enough that they appear to be fully charged in the charger but have such a high internal resistance that the terminal voltage under load won’t run anything. If u really want to test it u must put a load across your DVM probes and connect to the output terminals.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How i do it? A have a DVM and i have try several testing. Batteries are new and the charge is ok.any other tips?
さんによる
コメントを追加
回答を追加する
Angel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 76
