Is the battery replaceable
Has any one replaced the battery in these headphones? I can’t seem to find any guides on how to replace it. I would hate to throw out a perfectly good pair of headphones.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Those internal photos was exactly what I was looking for. I got the part number I was looking for. Thank you so much. I wanted that info before opening it.
このアンサーは役に立ちましたか?
Christopher Eckersen that's awesome. Best of luck to you and don't forget to make a guide
Christopher Eckersen there are not clear cut guides yet. Now it’ll be up to you to become the Pathfinder and create one. Yes, the battery can be replaced. Never easy since they (manufacturers) do not want us to fix things. With these headphones it’s actually straight forward. Basically, you remove the earpads. After that remove the four screws that hold the driver to the housing. The battery is behind the speaker nestled into the headset. I suggest you check this video (it’s dreadful but has a bit of valuable information on how to remove the drivers (speakers). Use this document Internal Photos 2316351 for the rest of it. The second picture shows you the battery etc.
This https://www.ifixit.com/Guide/new will help you to create a guide. It would be awesome for the next people that are looking for how to replace the battery.
このアンサーは役に立ちましたか?
The Replacement Battery for the Hesh2 is JHY602535 3.7V 450mAh 1.67Wh found on eBay for $5.99USD Shipped. You need to Solder the Positive & Negative Leads.
このアンサーは役に立ちましたか?
Did you upgrade your mAh while you were at it? If so do you double the current size or go for the biggest one that fits?
過去 24時間: 1
過去 7 日: 17
過去 30 日: 62
今までの合計 6,089
