メインコンテンツにスキップ
2020年5月発売の13インチMacBook ProはクワッドコアIntl 第10世代Core i5/i7プロセッサ搭載でIntl Iris Plus グラフィックス搭載(モデル番号 A2251/EMC 3348、4つのThunderbolt 3ポート)
69回答 すべてを表示
After screen replacement battery not showing or charging
So after replacing my screen, my macbook does not work without the charge cable, en booting or even opening Safari takes like 10 minutes.
Loud fan noises everything is laggy i can't even do a cmd + R cause booting causes like 10 minutes.
Before the screen everything was charging fine and working perfect, but now i can even work with it.
Anyone knows what the isseu is here?
Paid info:
Battery:
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント
Did you check the connections did you not get the connections properly set?
How about running the onboard diagnostics to see what it tells you. Restart your system and press the D key
Reference: Mac startup key combinations
Lastly, let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see iFixitでの質問に画像を追加する方法
さんによる
The connections are good, I am now trying the D key so its recovering. I keep you posted!
Thanks a lot for the quick answer!
さんによる
@danj Update: after pressing D and waiting like 10 minutes is chosen my WIFI and after password it kept loading for 4 hours en now i forced it to stop. So no succes even with the online recovery its horrible slow and laggy and loud fan noises.
さんによる
@dannydog - Sorry to hear that, Not sure why your system would do that. Are you able to get CoconutBattery working? If you can get that running a post a snapshot of it that might offer a clue.
You could try installing this great App TG Pro it will show you the sensors (including the batteries) If you get the full version it offers a bit more info.
さんによる
@danj Just updated my question, after 4 hours struggling to install tg pro these are the results.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Well! Your system doesn’t have a battery (or TG Pro is not seeing it) This points to a cable issue between the battery and the SMC control logic within the main logic board.
There is a small ribbon data cable which I suspect is damaged or the connector is. Review Step 9 & 10 in this guide MacBook Pro 13インチ Four Thunderbolt Ports 2020 バッテリーの交換. Note the little compression latch which needs to be lifted to release the cable and needs to be press back down (requires very little pressure for either direction) Double check the ribbon cable is properly secured and not damaged.
The GPU and drive errors are linked to the battery problem. Until we get the battery issue fixed we can’t address them.
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
@danj understood, ro be honest the flex cable does not look verry well, see my question i think you found the problem. I will order a new flex cable and see where i will go.
さんによる
@danj i wiped my macbook with icloud, now its stuck booting, i only see the apple logo even cmd + R does not work, online repair gives me an error after choosing my Wifi, cmd + S does not work.
How can i fix this issue?
さんによる
@dannydog - I'm not following you. iCloud has no bearing on formatting (wiping) your drive. Time to visit someone local who can help you hear.
さんによる
Hi @danj, i wanted to wipe my OS, but with CMD + R it did not work, so i wiped the whole macbook by icloud "find my device" after i did this its stuck at the apple logo.
さんによる
@dannydog - So you pressed the PANIC Button! The reason for that option is to prevent anyone access to your data.
You'll need to speak with Apple on how to recover from this condition. You may have made things unrecoverable if your system wasn't responding to the normal process.
But why did you think you needed to do this? Switching the battery would not have needed this.
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Danny Dog さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 49
今までの合計 2,066
