メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Inspiron 580は、基本的なコンピューティングニーズに対応します。すべての機能において最も高度なバージョンが搭載されているわけではありませんが、基本的な機能は揃っており、ユーザーに提供されています。
Possible Cooling system modifications
Is it possible to upgrade the CPU From an i5 to anything more powerful? or maybe a CPU cooler like a watercooled system or an ice cooled system? Also anybody have any GPU upgrade options, as the GPU in there is an aging geforce gt 220. Looking for kind of an internal overhaul without having to go to windows 10.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi,
The motherboard has a LGA1156 CPU socket and the chipset is a H57 Express so based on these parameters you can upgrade the CPU to an i7 870 (known to work with your motherboard) with normal CPU fan cooling
The ram can also be upgraded to 8GB i.e. 4 x 2GB DDR3 PC3-12800 modules.
Another way to increase performance is to replace the HDD with an sata SSD
Other than that given the age of the motherboard it wouldn’t be worth investing too much more into improving performance due to the limitations imposed by the chipset and the motherboard which were designed 10+ years ago - a lifetime in computer technology.
Here’s the service manual which may be of some help.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Actually the ram goes up to 16 gb, although not supported. i know this because i have 2 8gb ddr3 corsair cards in the computer. but i was wondering mainly about changing the cooling system from a fan to something like water or coolant.
さんによる 共有
HI,
What are you trying to achieve?
The motherboard and chipset will limit what CPU can be installed
Most probably you can't overclock the CPU in BIOS anyway so its not going to run too hot that it warrants water cooling.
さんによる 共有
コメントを追加
回答を追加する
Roman さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 15
今までの合計 506
