メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
XPS 13 9360は、2016年に発売された13インチのノートパソコンで、第7世代のIntelプロセッサを内蔵。2017年に第8世代のプロセッサにアップデートされました。
Fan not turning on
I repasted the cpu and applied some thermal pads to the heatsink. Popped the chassis back on and when i fired it up i notice the fan doesn’t turn on. Ran a startup diagnostic and it reports the fan is functional. I’m wondering if I put too much insulation that the fan isn’t being triggered? The unit gets a little hotter on the bottom chassis but seems to run faster/doesn’t throttle as hard and core temp app reports lower temps. I would like the fan to turn on or at least know whats up, thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Crispy  for as long as your computer works appropriately, leave well enough alone ;-). you can always monitor the temperature with software like HW Monitor and Core Temp. At high load, temperature should be hovering between 83°and 90° with the fan running at low revolutions (a good fan will be barely audible). For a manual/custom fan control check on here It’s part of the Dell Power Manager.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
So i reached out to parts-people.com and asked them about this issue, they advised that the temperature sensor is in the cpu meaning that what is being reported by core temp is accurate. In essence placing thermal padding to the bottom of the heatsink is creating a passive cooling system by dissipating heat onto the bottom aluminum chassis. This is why the fan wasn't turning on, because it didn't need to! :) the chassis got really hot at high load but the cpu temp remained at about 75 celsius and clockspeeds were at peak (3.2ghz -3.7) with very little throttling. If you don't mind the chassis getting very toasty I highly recommend this homebrew modification!
さんによる
Crispy, good so all is well and things are working as should.
さんによる
コメントを追加
maybe its the SMC or something on the motherboard was shorted
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@beanman56 "System Management Controller (SMC) is a subsystem of Intel processor-based Macintosh computers. not on a Dell
さんによる
コメントを追加
回答を追加する
Crispy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 26
今までの合計 1,704
