How can I erase the log in and password
How to reset imac. 20 inch with regular keyboard
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi
If you want to wipe the whole iMac do this
I’ve only ever done this with a wired keyboard but who knows a wireless one might work
Turn off or restart the Mac and when it turns on on the keyboard hold all at once alt or option(depending if your keyboard has it) Command and R and it should start internet recovery
Once you have waited out the timer with the globe you should be at a window that says MacOS utilitys,now you want to go to disk utility and wipe the drive in the iMac ,once you have done this hit the reinstall macOS and you should have a fresh band new copy of macOS installing
If you have any trouble please don’t hesitate to ask for help
このアンサーは役に立ちましたか?
Just as a disclaimer this will wipe the whole iMac and all the data on the iMac will be permanently erased
@Billy Bushman
It might be hard to do,
hold down Command (⌘) – V key to get to verbose mode,
i dont remember tho
このアンサーは役に立ちましたか?
To save your data, you will need a Hard Drive/SSD with:
To save your data, do the following:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 78
1件のコメント
Are you amble to log into the system at all?
Dan さんによる
