メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iRobot Braava Jet M6は2019年7月12日に発売されました。このロボット掃除機は、部屋をマッピングし、水を噴射しながらパッドを取り付けて床を拭き掃除します。
Why is it not spraying liquid
machine is brand new, just out of the box, and not spraying liquid. Yes, the reservoir is full, battery charged, front of jet clean….
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
Same issue here. Initially nothing came out of sprayer nozzle, now just a frothy bubble liquid dribbles down the front of robot but nothing sprays onto floor. On hold with customer service with an est wait time or “more than 30 min". Great.
さんによる
Change the pad, If you have put a white dry pad it will not spray. You have to put a blue pad on for it to spray
さんによる
コメントを追加
6件の回答
最も参考になった回答
I had the same problem. I cleaned filter. I also cleaned the jets at the front both with a fine stiff brush (as recommended) and with a WaterPik dental high pressure water spray flosser. Fixed the problem.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Brilliant suggestion. Worked perfectly. Just don't tell the wife what you're using her Waterpik for!! :D
さんによる
コメントを追加
It is sadly a fabrication error. I am now on my 5rh M6
Thay all had to be repaired. Every single unit wirks for 2 to 3 mobths if I'm lucky after which the same problem occurs. I cleaned the filters, tubes, reboot. Nothing. For some reason whatever it is they use inside, it cloggs and the unit breaks
1 golden tip: Do NOT buy the Braava. It is just utter crap. Sorry.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I just got a new Braava Jet m6 and apparently there is a manufacturing defect that will not allow cleaning solution to be pulled from the tank and sprayed because there is no way that air can be pulled into it to allow the solution to flow out. I burned a hole with a hot pin in the top of the tank and now it's spraying, no problem! It was the only thing I found that worked. Might be worth a try if you run out of options!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had this problem after some week, on may case, the water filter was dirty. The filter is below the water tank, after cleaning it very thoroughly, it worked again…
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
If all of the above fails and the BRAAVA has not been used or stored (or you purchase a used BRAAVA, you have to disassemble to get to the pump. If the rotating rollers that squeeze the tubing to pump liquid remain in the same position for a long time, it puts a crimp in the tubing. Pull the tubing from the pump, a simple squeeze will remove the kink, then away you go. Same prob with the Scooba also
さんによる
さんによる
The tip to put an air hole in the top of the tank worked when nothing else did. Thank you, Jennifer Parker!
さんによる
コメントを追加
Instructions say to Reboot the braava. This worked on my newly acquired used one.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Did not fix it my roomba
さんによる
i mean reboot is not always thing that can fix everything, i had braava too like 2 monts ago and it had same problem with liquid, local mechanic guy said that this problem is unfixable for me, and he said that i should buy new vacuum and showed me this vac right here https://www.cnet.com/deals/we-love-the-b...
さんによる
コメントを追加
The Braava uses a peristaltic pump that relies on the tubes being clean. Using non-approved cleaning fluids can block the tubes or make them 'sticky' and degrade the efficiency of the pump. There are YouTube videos on how to overcome this problem. It is not a simple procedure and would, I imagine, invalidate any guarantee. If it's under guarantee contact iRobot. I had a motor failure that iRobot diagnosed over the web and replaced for free. They were very helpful.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mary ragains さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 46
今までの合計 13,672
