メインコンテンツにスキップ
WesternDigitalのWDElements DesktopUSB外付けハードドライブの修理およびサービス情報。 3TB、4TB、6TB、8TB、10TB、12TB、および14TB構成です。
5回答 すべてを表示
Is it possible to turn this device into a portable drive?
Hello all I have a question, I have a couple of these devices in different capacities (along with the WD My Book) and what I am wanting to know is if it is possible to take the drive out of the inside and put it into another enclosure and make it a portable drive where it does need a power supply?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Yes, it is possible to put this drive in another enclosure (follow this guide). Before you get an external enclosure, make sure you're getting a SATA enclosure and the enclosure matches your Hard Drive (2.5” or 3.5”).
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
But is is possible to make it portable instead of requiring a power supply? Also, how do I know if the drive inside the enclosure is a 2.5 or a 3.5 without having to open it up?
さんによる
No, Everything requires power. It is labeled as INTERNAL USE because it requires 12V. An external drive only requires 5V that is supplied via the USB connection. Some older drives will only function with a double USB connector because they require more current than USB 2 can supply.
さんによる
ok thanks for your help, I kind of figured as much but was just wondering. Any recommendations for a good multiple drive holders, cause what I am really trying to do is cut down on the number of items I have plugged into power receptacles.
さんによる
コメントを追加
回答を追加する
Louis Wilson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 13
今までの合計 165
