How do I change the lcd?
how do i change the lcd?
Hi @jbsanchez
Here’s the hardware maintenance manual, taken from this support webpage for the laptop.
Go to p.49 to view the necessary pre-requisite steps and then the procedure to remove the LCD panel.
Here’s a link to the parts for the laptop.
Click on Select Commodity > LCD panels (4) to find the part numbers for compatible LCD panels.
Search online using the part number only to find suppliers that suit you best. Usually the part number can be found on the back of the LCD panel itself, if you wish to verify that you’re ordering the correct one.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 404
