メインコンテンツにスキップ
2012年6月発売。Core i7プロセッサ 、Turbo Boost / 最大1 GB DDR5 Video RAM
596回答 すべてを表示
Panic after changing battery
Got a battery kit for iFixIt, and it seemed everything worked just fine, no problem during the swap.
But when booting, now macOS panics after a while, and the Windows partition that was there too boots fine but with quite a few video artifacts. It makes me think macOS panis when switching to the graphics card but not really sure.
I had a USB key with VMware ESXi on it and that one boots just fine, I don’t think it’s using the graphics drivers at all.
Booting lid closed on an external monitor has the same symptoms.
Any ideas ?
[EDIT] Tried resetting NVRAM and SMC without success
Update (09/02/2021)
Here is a snap of the last line before crash
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
What do you see in the crash log?
Also did you try running diagnostics?
さんによる
Updated question. Thanks !
さんによる
コメントを追加
2件の回答
最も参考になった回答
Have you tried resetting the NVRAM / PRAM? This could solve the issue, but be aware that it also resets some minor preferences (see last bullets in the link).
If you suspect the graphics card to be the culprit, do you have a dedicated graphics card and are you running some kind of CUDA drivers? They might get reset as well so make sure you are using the most recent drivers depending on your OS. BTW, which MacOS version are you running?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks Tobias. Yes, NVRAM and SMC have been reset. That's a vanilla install of macOS 10, the latest supported by this machine (10.15).
The recovery boot also seems to stall but not always panics.
さんによる
コメントを追加
It appears the NTFS volume has a corruption! You’ll need to boot up under macOS and make sure the GUID volumes are in good order using Disk Utility. Then reboot under Windows and use Disk Management to repair the NTFS volume.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks, that's probably not related though. By then WindowServer should have started and graphical UI be up. NTFS issue is probably normal as the Windows boot we tested was shut down abruptly.
Thanks
さんによる
コメントを追加
回答を追加する
yann さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 69
