メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ASUS Chromebook C523NAは、2018年10月23日に発売されたASUS製Chromebookノートパソコンで、Google Play ストアに対応しています。画面サイズを拡大しつつ、よりコンパクトなデザインを実現した、NanoEdgeデザインを採用した最初のASUS Chromebookです。
My C523 Will Not Charge
My C523 Will not charge from either USB-C ports. The charger is good as it works on my wifes chromebook. I opened it up and everything looks to be connected properly. Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
I have the same model with same issue. Both ports won’t light up and can’t even turn on. Is there a way just to change the charging port?
さんによる
I ended up replacing the motherboard as I didn't trust my abilities in soldering on a board. Found one on ebay for around $150 I think. This was going to be for my kid at school so didn't want to buy new with the inflated prices pre-school year. Fairly easy install with the right tools. Got it all done and then the school came out a week before start and said outside computers not allowed as they had enough to go 1 to 1 for the year. FML...
さんによる
コメントを追加
1 件の回答
最も参考になった回答
If you wife’s Chromebook is the same model try swopping batteries.
If her battery charges fine in your laptop and your’s doesn’t charge in her’s then you know that you need a new battery.
Asus Chromebook C523Nのバッテリー交換
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Its not the same battery. Are there other indicators that would help diagnose a non-functional battery? On mine the light wont even turn on when plugging it into the charger. Does that lean to a bad battery or a bad motherboard?
さんによる
Hi @Sean Goodman
Just disconnect the battery and try to run Chromebookl with just the charger plugged in. If all is well then the battery is probably defective and I would guess shorting out the system.
It could be something else but let's just try this to start.
さんによる
I have the same problem, but disconnecting the battery and plugging it in does not allow the computer to run. What's the next step?
さんによる
@Peter Anderson
What is the make and model number of the laptop?
Do you get any indications on the laptop when a charger is connected?
If not maybe check if the DC-In jack is OK.
さんによる
try disconnecting the battery then plug it back in while the usb c cable is pluged into the chromebook that worked for me
さんによる
コメントを追加
回答を追加する
Sean Goodman さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 22
今までの合計 2,032
