locate sensor inside CF091
i need to open up Ninja and locate the sensor and bypass, even on a full carafe after 3 seconds it beeps and stops brewing
Probably not the sensor. It is probably clogged in the upper part before the spout. I have had 3 of these machines that all did that right after about a year…I finally figured out the problem.
このアンサーは役に立ちましたか?
Hi Brent! Were you able to unclog your machine? If so, would you be able to share how? Thank you!
Yes, please elaborate on how to fix this. Maybe cleaning with a pipe cleaner? Nothing seems clogged, though. The water comes out just fine. It just stops after a few seconds and beeps.
過去 24時間: 0
過去 7 日: 7
過去 30 日: 19
今までの合計 1,144
