メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
JBL Go 3は、コンパクトでポータブルなBluetoothスピーカーです。IP67等級の防水・防塵性能を備え、一度の充電で4〜5時間の連続再生が可能です。JBLGO3としても知られており、そのコンパクトな設計により、外出先や屋外でも気軽に音楽を楽しめます。
no Red Light while charging
Hi, I just bought a Go3 a few weeks ago, but by mistake my brother at some point put it to charge with a Samsung 15 watt fast charging charger, the speaker works perfect but apparently the red light when charging no longer lights up, everything else works perfect, even the white light is still on while in use. Although it may not be of much importance, but not having the red light does not allow me to know exactly when the battery is low (normally it blinked) or worse, even now I do not know when it is fully charged. So, what should I do? any idea, suggestion? or nothing to do and better buy another? thank you all
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
UPDATE:
After my problem arose, I decided to continue using my Go 3 and completely forget about the failure, then I recharged the battery using its original cable as always but this time connecting it to the USB port of my Mac mini 2011. The red light never ever returned until the today. "What I think is that ... probably when it was erroneously recharged using fast charging from a Samsung cell phone, the battery or charge manager was" out of calibration "(is what I think). several times with the "proper" load, the speaker recalibrated (if what I'm saying makes any sense). Thanks for your help. No need to open the speaker, I was afraid of damaging it.
さんによる 共有
コメントを追加
1 件の回答
@hotdavesweet sounds like there are issues with either the battery or the power management IC. I would take a look that the board and check for obviously damaged components and at minimum replace the battery. Use something like this video to work on it. As always, if in doubt or unsure of what you are looking at, you can always post some good pictures and we will try to assist you.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Thank you, I'll check inside. The video is for Clip 3, mine is Go 3
さんによる 共有
@hotdavesweet sorry about that. Use this one instead.
さんによる 共有
Thank u so much
さんによる 共有
コメントを追加
回答を追加する
hotdavesweet さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 17
過去 30 日: 42
今までの合計 4,192
