メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1.7 GHz デュアルコア Intel プロセッサ (Turbo Boost 最大 2.6 GHz)、3 MB 共有 L3 キャッシュ
Display not working when using a certain ssd
I was trying to reinstall the MacOs on my old macbook but it doesnt seem to boot anymore with the current ssd. If i unplug it or use a different ssd i can boot.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
What is the SSD's you are working with? Make and Models
さんによる
@danj Im using the original ones that came with it. I believe its a 128GB Toshiba
さんによる
コメントを追加
2件の回答
最も参考になった回答
I’d boot from an external source, reformat the dive, run Disk Utilizes on it and then try installing a new system from the external source.
This failing, it’s time for a drive replacement:
MacBook Air 11" Mid 2012 SSDの交換
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Even though it was working perfectly fine before? I had reinstalled the OS then it turned off again so i reinstalled after, after that is when it no longer booted. If the SSD is plugged it, it doesnt boot past the chime. If i tkae out the ssd i can do command + R to recovery mode easily
さんによる
Don't try to do a restore from a drive that's not in the machine, The recovery files and your data are all on the same drive. So do the the work on the internal drive from an external.
さんによる
コメントを追加
This SSD has a known issue! Apple issues firmware fix for Toshiba SSDs in 2012 MacBook Airs & Apple Recalls Mid-2012 MacBook Air For SSD Replacement – 64GB and 128GB SSD Systems Affected
Its a bit on the late side, but its possible you just don't use your system that heavily so it took a bit of time.
Sadly, Apples extended warranty program has ended for your system. Time for a new drive!
The Apple SSD is a bit faster than the OWC drive, but its more expensive.
Replace or upgrade the SSD in your laptop. This SSD is compatible with a Mid 2012 MacBook Air 11" or 13" laptop.の画像
製品
OWC Aura Pro 6G SSD for MacBook Air 11" and 13" (Mid 2012)
$52.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jun Hyeok Yoon さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 13
今までの合計 386
