Machine does not supply water
Why does water not come into machine
Hi,
Have you checked that both of the water supply taps (faucets) for the washer are turned on?
Does it do this when either hot or cold is selected?
If hot works OK but not cold (or vise versa) then there may be a problem with the water inlet valve in the machine or perhaps the control board.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 23
今までの合計 612
