メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Core 2 Duoプロセッサ(2.4 GHzまたは2.66 GHz)搭載のモデルA1347。
random restarts with random kernel. How to troubleshoot?
Getting random restarts and random kernel errors like: mdworker, imklaunchangent, AssetCacheLocato, to UNKOWN and among others.
I did a fresh install quite a few times but same results. I’ve also tried removing one SO-DMM , then the other, different drives, different RAM and essentially it still restarts with random Kernel errors.
Mac Mini mid 2010, 16GB memory , 250GB SSD, macOS High Sierra
Any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
What happens when you use an external drive boot up and run your stuff from it?
さんによる
I tried the OEM RAM and it fixed the issue. I guess i was using incompatible RAM. Thank you for the reply Dan
さんによる
コメントを追加
1 件の回答
RAM is becoming a bigger issue these days as people often put in faster RAM than what Apple spec’ed for the system thinking they would get more performance.
The problem is the speed of the write and access (Strobe) of the data going in and out also needs to be considered besides the JDEC spec: 204-pin PC3-8500 (1066 MHz) DDR3 SO-DIMM. This is the Row Access Strobe (RAS) and Column Access Strobe (CAS). So make sure to use the correct SO-DIMM’s not too slow and not to fast!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Luis さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 24
今までの合計 318
