メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP LaserJet CM1415fnwは、Hewlett Packard社製の多機能カラープリンターです。
Having several paper jams
Every thing seems to be working fine with the printer from a communication point; however, every 2nd or 3rd piece of paper jams as it is coming out. I have check to ensure no paper is clogging port where paper is being dispensed and cannot understands why it wrinkles.
Please advise,
Paul
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
you may need to dig a bit deeper. there is a roller that rolls the paper through on most printers. Some times there is 2-3 of them. And it could be at any of those that is the problem. I believe on your printer you can pull the back cover off to get a better look at all the rollers. you may have a small piece of torn paper that only comes around and causes issues every so often.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Paul Staples さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 511
