メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2007-2018 Jeep Wrangler(第3世代、JK世代)の修理情報。このオフロード車シリーズには、Sport、Sahara、Rubicon、Unlimitedの各エディションが含まれます。
tipm/ totaly intergrated power module
The TIPM’s on the vehicles have a high failure rate, they are expensive to replace and require an exchange, I belive its just some corrosion on the board and they are repairable. part# is 4692236ak and list price is $880.00
Update (07/07/2021)
I just want to see Ifixit Do a tear down and repair video on them.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント
Albert Anderson so what is your question? Yes they are expensive $1100 for my Jeep
さんによる
So it depends on the failure. There are several issues with these. And I believe there is a bypass kit available that allows you to bypass certain failed issues. I know I purchased the bypass kit to have on hand for my Chrysler mini van. But I believe the jeep has similar issue. and will not start when certain things fail.
さんによる
@gkjarhead do you recall what it is the kit? Maybe that gives us an indication of what fails.
さんによる
@gkjarhead i see. They are bypassing the relays. Since it is a failure that seems to cascade makes me think there are issues with the traces. I guess we just have to see what we can find out. Thanks for sharing.
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
Albert Anderson I don’t think iFixit is going to tear it down since those folks are just busy with all the other things they have to tear down. They really don’t have the people power to do so. You see, that is the beauty of Answers on here. Hopefully somebody has done it and post a guide soon or even better if you start tearing it down and be the first one to do so. You can then create a guide https://www.ifixit.com/Guide/new and post it for the rest of us. Now I do not have mine anymore since I had to return it to Jeep but maybe we can find a TIPM and work on it
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Albert Anderson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 31
今までの合計 1,243
