メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年9月21日に発売されました。モデル番号A1920, A2097, A2098, A2100。GSM もしくはCDMA / eSIM もしくはナノSIM / 64, 256, 512 GB / シルバー、ゴールド、スペースグレイ。(正しい発音は"iPhone 10 S.")
What is the TG0B sensor?
Does anybody know what the TG0B sensor is and what could cause thermalmonitord returning “not alive” with context SD: 0 BC: 1 Missing sensor(s): TG0B
When that happens, the shown battery filling level drops to 0% and shortly after it will reboot with the mentioned error in the panic logs.
First I suspected that the error might be related to the lightning port. But replacing it didn’t fix it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
4 件のコメント
hi if you solve this problem please tell me what you replacing!
さんによる
Hello , I am facing the same problem with my iphone . If you have solve this problem ,can you tell me by replacing what you solve this problem?
さんによる
@mehrajsalfi Start by following @oldturkey03's advice and replace the battery. As he said, sensor TG0B is located on the battery, so that's the place to start.
The sensor is read by two signals that pass through the battery connector and through a couple of components mounted next to the connector. Occasionally a component will get knocked off the board in the process of connecting and disconnecting the battery, which can cause that same error.
さんによる
Dan betul ternyata fleksibel sensor kamera depan sobek
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@mfmayer start by replacing the battery. If you already have done this, check the components around the battery connector. Make sure you did not pop one off. Those can be causes for this as well. Ultimately “SD: 0 Missing sensor (s): TG0B” - battery / TIGRIS; result is that the device does not see the battery.
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
回答を追加する
Matthias さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 31
過去 30 日: 108
今までの合計 15,723
