メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Googleが2018年10月に発売した第3世代のPixelです。
Unable to make calls
Had did a factory reset on my Pixel 3 twice and didn’t find any fault in the SIM card given that it works on other devices. Yet, I am facing intermittence with the network and most of the times am unable to make any calls or SMSs. I am not sure if it is an issue with the antennas or the SIM card reader.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @j370,
Not sure if the setting is the same on your model, but check the signal strength of the network signal.
Go to settings->system-> about phone -> sim status.
Remember the signal strength is in -ve dB so the higher the number the weaker the signal actually is.
このアンサーは役に立ちましたか?
スコア 1
20 件のコメント:
Hi @jayeff, I am getting values around the 100 range. May I also add on that mobile data seems to be working. I have 2 SIM cards, one that doesn't always work on my device and another that is not facing any issues. I am quite certain that the signal around my area is ok as my device was previously working. Not sure what are your opinions?
さんによる
@j370
What is the signal level like with the good SIM card?
Try clearing the phone and messages app cache data Go to Settings Apps and Notifications and select the app.
Try starting in safe mode although since one SIM works OK this may not prove anything
さんによる
@jayeff, that was the signal level on the good SIM card, looking at another device I had, I am quite certain that the signal level is roughly aroung this range. As I mentioned, I had already did a factory reset so I am ruling out software glitches. Starting in safe mode is the weird thing where it works once or twice but mostly doesn't seem to be reliable.
さんによる
@j370
Are both the SIM cards from the same service provider?
さんによる
@jayeff, no they are not. I had gotten a replacement SIM for the one that isn't working so well. Can also add on that both SIMs are unable to place calls.
さんによる
15件以上のコメントを表示
コメントを追加
回答を追加する
[deleted] さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 14
今までの合計 236
