My Inspiron 7579 is crashing. Help.
The computer is crashing and BSOD always shows up. I’ve tried blowing on the fan, but it didn't help. help
この質問は役に立ちましたか?
この質問は役に立ちましたか?
BSODs are usually software-related. Try resetting your computer by going to Settings -> Update & Security -> Recovery. Under the Reset this PC, choose Get started. Follow the prompts.
This will remove your apps and settings, but may prevent further crashes.
このアンサーは役に立ちましたか?
I am going to say that by you laptop crashing, then it does come up. If so go to Event Viewer and then Window Logs and see what might be causing the issue. Also the BSOD error would be helpful. Check to see how much RAM you are suppose to have verses how much RAM your system is showing you have.
このアンサーは役に立ちましたか?
First take a data backup of your important data now try reset the settings of your laptop as it was new. If it didn’t work then just change the window of your laptop.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 70
Provide a image of the BSOD or the error code, photo would be more useful
Josh Cook さんによる
