メインコンテンツにスキップ
Device repair and information for the Vizio D-series 50" LED television with model number D50n-E1.
77回答 すべてを表示
Backlight is out but tv still works can see with flashlight
Vizio tv D55un-e1
Watching tv one day and the next day it went out and I waited one day and tried to see if it would come back on and it didn’t I thought it was completely black until I used a flashlight and could use the remote to still do things.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You are correct with the troubleshooting, that the backlight is out. That is most likely caused by a bad inverter board. If you are electronically technical you may be able to troubleshoot and fix it on a component level. Otherwise, a board replacement is necessary.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kai さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 89
