メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Galaxy A20sは、2019年9月にSamsungから発売されたミッドレンジAndroidスマートフォンです。モデル番号SM-A2070、SM-A207F/DS、SM-A207M/DSで識別できます。
Replace screen. still not functioning.
My A20 hand an encounter with a wall. the wall won. Cracked the screen. Ordered and replaced the screen. ( Something I’ve done quite a few times on J3’s…) it seems to power on, but no screen at all. when plugged in I get the charging chime… I’ve examined the ribbon cables with a magnifying glass, there does not seem to be any damage there. I ’spose it could have damaged CPU board… what am I missing?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
2 件のコメント
Hey bro I replace the screem and it won't show anything I feel it vibrate when I touch the power button I also try back the old screem and still nothing but it's powering up no display same here please help
さんによる 共有
Same issue any solution please. . . .
さんによる 共有
コメントを追加
2件の回答
最も参考になった回答
Hi @mlohre ,
With the phone switched on, try shining a torch at an angle close to the screen and check if there are any images showing. They will be very faint if they're there.
If they are there, then there is a backlight problem. Either in the display (new display I know but still...) or perhaps with the backlight power supply from the systemboard.
I don't know the phone but with other makes of phone there is a backlight fuse close to the display cable connector on the systemboard.
You may have to use a DMM and start checking components close to the connector and see if any are open circuit. Do this with the power disconnected. If any are open circuit it may be a fuse but it could also be a capacitor and you would have to know how to test them to be sure.
If there are no images showing then the problem may be the systemboard or then again it may be a faulty new display. The only way around this is maybe to temporarily try another known working compatible display to prove it one way or the other.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
How to make front camera clear
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Marcus Lohre さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 25
今までの合計 3,073
