メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年後半のMacBook Airのマイナーアップデート版に関する修理情報とガイド。モデル番号(A1932)およびEMC番号(3184)は共通です。このモデルはTrue Toneディスプレイを搭載し、バッテリーがわずかに改良されています。
Left hand speaker muffled and staticy
Okay, my MacBook Air’s left-hand speaker is weird. It very very muffled and full static when compared to the right.
I thought it could be water damage and decided to replace it. I did that myself and it all went well and then went to check and no change on that speaker. It was the same as before not even a single change or improvement.
I ran Mac diagnostics, nothing came up. I also reset NVRAM/PRAM as someone had suggestion that might help. Still nothing. I’m at a total loss of what to do.
Also, I am 100% sure when I got it first it was working fine.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
What do you hear when you plug in a good set of headphones in via the headphone jack? Use the balance control to bias which headphone is playing. Do you hear it with the headphones?
If you do then the MacBook Air 13" (Late 2018-Mid 2019) Audio Daughterboard or MacBook Air 13" (Late 2018-Early 2020) Audio Daughterboard Cable to the logic board is the issue. If its clean on both sides, then the logic board speaker cable connector has a problem.
Review this guide: MacBook Air 13インチ Retina Display Late 2018 オーディオボードの交換
Replace a torn or damaged cable connecting the logic board to the audio daughterboard containing the headphone jack and connectors for one speaker and the Touch ID sensor.の画像
製品
$19.99
Replace a corroded, dirty, or damaged headphone jack by swapping in an audio daughterboard containing the headphone jack and connectors for one speaker and the Touch ID sensor.の画像
製品
$59.99
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Earphones have no problem with this. Only occurs when I use the in built speaker,
さんによる
Look at the logic board for corrosion.
さんによる
@danj I am pretty sure there was none since I did open up when replacing the speaking thinking that was the issue, and saw nothing much there in terms of it looking diffrent.
さんによる
I think you'll need to bring your system into someone who has the skills to diagnose your issue. There is a limit on what I can offer for help.
さんによる
@danj Thank you. Just wanted to exhaust all options before I did that in case it's something I can fix on my own. Really appreciate you taking you time to try and help me.
さんによる
コメントを追加
I had the same problem with 2 Macs, the solution was to clean the grille with a dry/clean toothbrush. The issue was that the micro-holes were blocked, which can be confirmed by passing light through them.
I could diagnose the problem by connecting the speaker without installing it, I leave it carefully hanging and it sound really loud.
I attach a photo of the blocked micro-holes.
画像
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
@oliversi - To many bread crumbs! 😆
さんによる
it acted more like a cheese grater :)
さんによる
コメントを追加
回答を追加する
SeanErik さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 29
今までの合計 790
