メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
4インチディスプレイ / 多彩なカラーバリエーション / 3種類のモデル展開 / 16, 32, 64 GBの容量
Forcing an undercharged battery to charge?
I replaced the screen on my iPod touch 5, but when I went to test it, it got stuck on the charging screen and sometimes flashes the Apple logo. I checked with a multimeter and the battery is at 2.69v. I left it overnight to no avail. Is there any way to force the battery to charge without replacing/desoldering the battery?
Update: I’ve gotten it to 2.9v leaving it on charge for a few more hours and making sure it was the battery flat screen, I’ll try leaving it overnight again.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
try this
iPod Touch 5th Gen won't boot passed the APPLE screen
also on youtube northridgefix and louis rossman both repair apple products REGULARLY. you might be able to find a video with your problem also.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
It's actually not even turning on when not on the charger. In that thread, it seems like the battery is charging and working normally.
さんによる
if its not turning on when not on the charger that would indicate the batter circuit doesn't know the battery is there to draw power.
id say if you haven't already:
check connections be sure to look for lifted contacts or bent pins.
look for corrosion on the board, typically around the chips and resistors.
make sure there aren't and SMD components that have been knocked loose \ off the board.
the SMDs can be VERY easy to brush over and pop one lose
さんによる
@logixal I check with the multimeter and it is 2.9v, it's probably not enough to even show the low power screen
さんによる
コメントを追加
回答を追加する
TheYootz Media Group さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 16
今までの合計 562
