How do I fix this screen?
この質問は役に立ちましたか?
Hi,
The screen is cracked and will need to be replaced as it cannot be repaired.
(click on image to enlarge for better viewing)
Use the link in the answer above to view the replacement procedure.
Replacement screens are available online. Just search for XE550C22 LCD screen to get results for suppliers that suit you best.
このアンサーは役に立ちましたか?
Check that the screen cable is correctly connected.
This video will show you how to take it apart.
https://www.youtube.com/watch?v=Spriegms...
This video will show you how to replace the screen but check the cable first. If it is not the cable that is the problem you will have to replace the screen.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 362
